removal of rear hubs...how?
Hello everyone. I need to remove the rear hub on my TP3. The back plate is damaged (the holes at the bottom are ripped) and I need to repair.
I cannot see how the hub is removed from the axle. I will add pictures tomorrow to help explain.
I have been able to remove the wheel, cover and the brake shoes, but cannot see how to get the hub off to remove the back plate.
Thanks
Thanks
steve swann- Messages : 8
Re: removal of rear hubs...how?
steve swann a écrit:Hello everyone. I need to remove the rear hub on my TP3. The back plate is damaged (the holes at the bottom are ripped) and I need to repair.
Thanks
Bonjour à tous. Je dois retirer le moyeu arrière de mon TP3. La plaque arrière est endommagée (les trous en bas sont déchirés) et je dois la réparer.
Je ne vois pas comment le moyeu est retiré de l'essieu. J'ajouterai des photos demain pour aider à expliquer.
J'ai pu retirer la roue, le couvercle et les mâchoires de frein, mais je ne vois pas comment retirer le moyeu pour retirer la plaque arrière.
tu a sortir les arbres de transmission ?
I have now got the plate off (I couldn't see the edge before) and then pulled it all apart to repair the back plate. I had to enlarge the lower holes, then weld the bracket thing back in.
I have blead the brakes after much difficulty getting the shoes back on, and it appear to be fixed. I have not test driven yet.
I have another question. I may need new brake pipe unions. Are the 7/16 inch or metric. The copper pipe got a bit twisted and could be replaced.
Thanks
Thanks
